subwoofer hum
Discussion in 'Subwoofers' started by jan, Jan 6, 2002.
  1. jan
    jan
    I have just bought an Eltax hollywood 8 sub and connected it to my kenwood 5050 amp.I can hear a background hum all the time through the sub.Disconnecting the line in to it removes the hum so it is not the sub.Is there any way to remove.It is not overpowering but on quiet scenes in a dvd I do notice it.
    cheers
    Jan
  2. torimusic
    torimusic
    I had a Polkaudio PSW-50 sub which had a hum problem. I disconnected the earth lead in the mains plug and this solved it.
