Subwoofer hum on BFD
Discussion in 'Subwoofers' started by MickB, May 23, 2004.
  1. MickB
    MickB
    May 15, 2004
    486
    28
    Hanslope,Bucks
    +30
    When I switch the BFD on, I get a constant humming from my PB2 sub, however disconnecting the earth cable in the mains plug eliminates this, but sounds like a dodgy tactic?
    Also, when I switch on the BFD, I get an extremely loud WHUMMP from the sub which surely can't do it any good, is there any guidelines for sequencing of switching on processor,BFD,sub,etc, or can this be eliminated another way?
  2. Ettepet
    Ettepet
    Feb 7, 2003
    738
    The Netherlands
    +19
    The hum is very probably a 'ground' loop, where at least one other Audio-component is connected to earth. A solution is to not ground all components that have an earthed connection. In some cases using optical is a solution, because that isn't electrical.
    You should avoid switching (ON/)OFF the BFD while the sub is on, as everyone else I've heard has the same problem.
  3. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    I managed to cure mains hum on our sub (earthed) by earthing the (double insulated, and therefore NOT earthed) AV amp by taking a single wire from the phono ground on it to the earth pin on a mains plug!
  4. Ettepet
    Ettepet
    Feb 7, 2003
    738
    The Netherlands
    +19
    Well, whatever fixes it. My Yamaha came with a grounding wire, never needed it. ;)
    The fun thing about the BFD is that you can have several settings and switch easily from one to the other. Handy for comparison reasons, and to moderate bass for certain music (haven't found the need for that yet with my PB2+).
    Have you found a good spot for your sub yet?
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Are you using the balanced connections on the BFD? If you are then you probably shouldn't be which may well cause the hum. :)
  6. morg
    morg
    I had mains hum on my subwoofer changed the interconnect to optical which cured
    the problem completely.
