Subwoofer help
Discussion in 'Subwoofers' started by mwallan, Sep 18, 2004.
  1. mwallan
    mwallan
    Jan 20, 2003
    984
    +78
    Im in need of some help :lease:
    My little boy was playing next to my sub (kef egg 2005) or with it !!! when there was this POP sound. Now the sub does not work the lights are green and I dont think his little fingers could have done anything to the amp Denon 2802 to stop the sub ????.
    I have checked all the cables but im lost to the problem
    Is the sub dead ?????
    If so what should I replace it with prob could go up to £300 at a push
    Any advice is more than welcome and the little boy is 14 months old so his hands are everywhere
    Thanks in advance
    Marc
  2. recruit
    recruit
    Hi mwallan,
    Have you checked the possible fuses eg Plugs or if it has one on the back of the sub that is accessible? :confused:
    Sorry i missed the Green light bit do you mean that light is on the sub :rolleyes:
    John :)
  3. mwallan
    mwallan
    Jan 20, 2003
    984
    +78
    HI
    No I have not checked the fuse. as i presume that ok as the green light is on the sub changes from red when not in use to green so I dont think is a plug fuse but I dont know where to look for any other fuse on the sub any ideas or help ???
  4. recruit
    recruit
    Sorry mwallan i am not too famliar with Kef subs, could be that the amp is blown but then you can probably just replace the amp or take it to your dealers for them to check it out.
    I think there are quite a few Kef sub owners on here maybe they can assist more
    Good Luck mate ;)
    John :)
  5. mwallan
    mwallan
    Jan 20, 2003
    984
    +78
    Thanks for the help john,
    I dont think the amp is blown as the other speakers still work but i could be wrong and I cant see how either would have blown as my other half never lets me play it loud :rolleyes: is there any other way i couls test the sub to see if thats the prob ????
  6. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I think he means the amp in the sub,i would get it fixed at a shop, or is this an excuse for an upgrade :devil: .
  7. braincapers
    braincapers
    Jan 2, 2004
    35
    My sub has exactly the same problem. I'm taking it back to the shop at the weekend. The guy at sevenoaks hifi didn't sound surprised. I wonder if this is a known fault?
  8. mwallan
    mwallan
    Jan 20, 2003
    984
    +78
    let me know what they say and how much it costs!!! Im going to get a sub this weekend the kappa infinity is calling going to see what it sounds like and its only going to cost £320 which is a bargain i believe as these retail up to £750
  9. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Shouldn't cost anything, doesn't all KEF gear come with a 5 year warranty?
  10. braincapers
    braincapers
    Jan 2, 2004
    35
    Well it took a couple of weeks but Sevenoaks fixed it under guarantee and all is well.
  11. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    this seems to be a known and fairly common fault of these subs..!! this has been discussed elsewhere - tho, think it may have been a different forum...which I can't say because it'll be edited out..!! freedon of speech and all that... :laugh:
