Subwoofer help needed!
Discussion in 'Subwoofers' started by gingerone, Feb 25, 2003.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    I'm getting an intermittent fault with my sub, now and again it just cuts out altogether. When this happens I have tried unpugging and re-plugging to no avail but if I pull out the sub cable and replug it, then it works for a while.
    I have tried using a standard phono lead and although the sound quality was terrible the problem stopped.
    Could it be a faulty lead?
    p.s. I have an REL Quake and a pioneer vsx-c300 receiver.And I am using the cable that came with the sub.(problem happens on ntl and dvd)
    Thanks.
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,486
    71
    Newcastle
    +82
    Sounds to me you have already solved the problem
  3. gingerone
    gingerone
    Dec 10, 2002
    2,404
    +289
    Any reccomendations for a decent sub cable? (£10-£20)
  4. Ravi 123
    Ravi 123
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,486
    71
    Newcastle
    +82
    Richer Sound do a 10mtr for £20 and a 5mtr for £13
    ]here
