Quantcast
Subwoofer for Panasonic SC-AK77 Mini System
V
Vladi
This mini system has five speakers and has an "out" for subwoofer (not part of the package).
Can anyone suggest some basic, not expensive subwoofer (preferrably Panasonic - if they make them) that will fit with my mini system?
Thank you.
Ian J
This is a Pro Logic system only and the front speakers have uintegrated "Super woofers". The normal consensus of opinion is that you need to spend around £200 minimum to buy a decent subwoofer with the Mordaunt Short MS309 at £230 being the cheapest decent subwoofer around.
In view of the total cost of the Panasonic unit it would seem a little odd to spend £230 on a subwoofer to go with it.
