subwoofer for Marting Logan speaker system
Discussion in 'Subwoofers' started by dragonfly, Nov 11, 2003.
  1. dragonfly
    dragonfly
    Aug 4, 2003
    141
    surbiton
    +3
    I am in the process of changing my Mains to Martin Logan Aeon and Cinema Centre but the price of Martin Logan subwoofer DESCENT is £3000.
    I would like an advice from Martin Logan owners as to what type of subwoofer they have got,or maybe i have to stick with martin Logan's own sub?:confused:
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    You don't have to stick with the ML range of subs.
    Any good quality sub would be suitable. Bass frequencies have less tonal character than the upper range. So matching isn't a problem.
    Something like a Rel Stadium III(£1500) or Stentor III(£2500) would be a nice match - both very musical.
    Depending on your leaning, some AV subs maybe suitable too, like the Servo15, Velo DD18 etc.
    Don't limit yourself to an ML sub when there are many better options at cheaper prices!
  3. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
  4. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
  5. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    The HGS18 works very well for movies, but looses out on music... your Aeon's will go low enough, unless you are playing heavy metal or dance..
    If you are just about to buy, get a demo as part of the package.. One warning however, my old Rel Strata II couldnt integrate and you will need to spend some real cash...
    Good choice of speakers, but them I biased!
  6. marck
    marck
    Jul 10, 2002
    600
    London
    I am in the same position - waiting to change my REL to something which will fit in with the rest of my system.
    Unfortunately I do not have room for the Descent, so I am going to be audtioning the Depth. If you have room and can afford it then it is the one to go for. If not consider the Depth - around £2k. There is also the Grotto, which is about the £1k mark.
    All of these will integrate perfectly with the rest of your ML's.
    Let me know what you audition....
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,481
    71
    Newcastle
    +82
    Charlie Whitehouse is your man who could possibly help
  8. dragonfly
    dragonfly
    Aug 4, 2003
    141
    surbiton
    +3
    Sorry what I was meant to ask was that who is Charlie Whitehouse, how can you put me through to this person?
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    look to a low distortion sub, not a REL per se for great performance with the ML, you will notice the difference
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    sorry forgot to mention, it is especially obvious with electrostaics and high bass distortion
  11. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Charlie Whitehouse has Martin Logan speakers and used to be a member of this forum but is no longer.
    paublo and marck are not only Martin Logan owners but are also members of this forum and willing to advise you ;)
  12. marck
    marck
    Jul 10, 2002
    600
    London
    Sure can advise...
