chavo
Established Member
Hi. i have a couple of questions, to begin with my set up.
Onkyo 607 Amp
Tannoy SFX sides, Rear and Sub
Cambridge Audio S70 fronts
Cambridge Audio S50 Center.
1. my Tannoy SFX 5.1 Sub has a couple of settings on the back. it has a L/R Jack input and it has a pair of speaker clips (the screw types) my Amp has a purple Sub out Jack. i use a standard Phono (yellow) cable about 5ft long in to the L jack in on my sub. this is the only connected cable to the amp. The speaker has a Volume control and a Crossover nob. I read the Crossover thread and understand the principles but that was aiming at the settings in the amp and not the settings on the actual SUB.
2. When i play a DTS HD Master Blu Ray the amp switches to DTS HD MASTER automatically. this from my understanding is a 5.1 format. i have 7.1.
If i switch my amp to Dolby Digital EX does this mean that i have turned the DTS HD MASTER OFF?? what about if ui switch to NEO:6? basically i want DTS HD MASTER in a 7.1 format... is that possible?
3. My front speakers are the cambridge audio S70. They currently have a bridge linking the 2 terminals and i hook them up via 1 cable to the front L/R respectivly. i have the ability to should i run an individual cable to the speakers, would it make any difference? i understand that bi amping is when you use a different amp (2 amps in total) and i do not want to do this. am i best leaving them bridged or should i wire them manually? as i already run a 7.1 which outputs would i be best wiring them to?
Onkyo 607 Amp
