Moggsy
Established Member
Hi all. Noticed last night there was nothing coming from our subwoofer and saw that LFE cable was at a funny angle. Wifey immediately looked sheepish and said she’d moved it ‘out of the way’ when cleaning!
Just had a good look at things and the pin on the sub end of the cable has snapped off inside input module . I’ve had the panel off to see if I can prod it out again, but it’s a sealed housing.
Had a quick look on Google and can see you can buy LFE to RCA cables. Is this a good option? What if any would I need to do with sub settings? I saw in the manual using an LFE cable to connect up means the amp ‘tells’ the sub what to do with frequencies etc. Would it still be the same with the new cable?
Thanks for any info…
