Subwoofer connections
Discussion in 'Subwoofers' started by Fonzerelli, Jan 21, 2005.
  1. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    Hello
    My Amp has a sub out, which is only one lead but my sub had two holes it can go in, one marked hi and the other low. which do i put it in?? there's nothing in the manual either, i looked :(
    Also there are binding posts for speaker cable, what are these ones for?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    What sub and amp are you using?
    I would guess you need to connect your amp's sub out to the low input on your sub using a normal RCA-RCA lead.
    The binding posts are to enable the sub to be used with a "high level" signal, that is, from the amplifiers speaker outputs. It is usually put "inline" with the speakers.
