Subwoofer connection
Discussion in 'Subwoofers' started by calypso, Feb 4, 2003.
  1. calypso
    calypso
    Feb 3, 2003
    Switzerland
    The subwoofer output on my AV amp and that on the back of my subwoofer (LFE connection) are both female phono plugs.
    I am using the normal coax cable to connect (male phono plug at each end) but I was wondering whether this rather thin cable was appropriate.
    Are there any special (heavy duty) cables available that also come with male phono plugs at each end?
    Thanks,
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    There are numerous subwoofer phono cables out there from the likes of IXOS, QED, Monster cable etc. I use the IXOS 1141 Gamma (3m) + a Studio reference 1/2 metre phono to connect the sub to the parametric equalizer. In other words, you can use any phono cable for sub duties, better shielding can be had on subwoofer cables is all.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Any decent quality phono cable will do the job just fine,being sure to use a cable of similar quality to the rest of your system.....I use and unshielded XLO cable in mine,with no problems.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Just make sure that you upgrade your cable if you ever get yourself some decent equipment ;)
  5. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    LOL,Ian....it works just fine for the moment...if I ever try upgrading again,I expect my wife will probably upgrade me!
    (BTW XLO signatures aren't that bad!):rotfl:
