Subwoofer - connection
Discussion in 'Subwoofers' started by Ridcully, Jan 7, 2003.
  1. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    Right, I think I must be going through a massive stupid moment but here goes.
    Borrowed a sub from a friend to see how much difference it made. I have a Technics DX930 receiver and the sub is a KEF PSW1000. The receiver has a 'sub woofer out' RCA and the sub has a right and left line in RCA. I have tried both / either connection using an rca cable but I get what I would call mains hum as though something isn't grounded.
    Have I
    a) wired it up wrong
    b) got a knackered receiver which I've only just found out about as this is the first time I've tested the sub thing on it
    c) something else
    Anyone, Please
  2. jim.rae
    jim.rae
    All the subs I have used only have one phono in from the amp...
    Sub sound by default, is mono.
    What does it say on the phone in sockets on the sub?
  3. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    The subwoofer rear has the following.
    Speaker input left +&-
    Speaker input right +&-
    Speaker output left +&-
    Speaker output right +&-
    Which look as though they take the main speaker inputs and then feed these to satelite speakers. I am not using this
    Line in left - RCA
    line in right - RCA
    which are the two I mentioned above. The instructions seem to indicte that both are wired when using a pre amp. Or just to line in right when having a subwoofer output from an amp. This what I tried.
    High pass output left - RCA
    High pass output right - RCA
    Looks to be a loop through to a power amp for satellite speakers, if used in this configuration.
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    It should go into the line in on the sub, from the subwoofer pre out on the av reciever.
  5. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    Yep. That's what I did. And I get something similar to a mains hum.
  6. DaveP
    DaveP
    How good is your lead? I had a bad attack of the hums but got a better quality lead and it improved it no end. Also, make sure it doesn't go near any mains cables or plugs!
    DaveP
  7. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Have you set the sub out (LFE) on the amp to on? If your main speakers are set to large, this may be disabled. Go into the amp's (onscreen) menus......
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    left or right makes no difference... although if you added a y-splitter to the end of your sub lead you could feed both left and right, this apparently improves the sensitivity of the sub's auto-on setting which switches intself off if no signal is detected.
  9. neoxp
    neoxp
    I have a PSW1000 and have it connected from the sub-out on my amp via RCA cable to the right RCA input on the sub. I use QED cable. This appears to be the same way you have. This worked out of the box. I assume the sub is OK?
    Some people actually prefer to use the speaker inputs anyway. To do this you run another set of speaker cables to the sub from your amp (the same outputs that feed your front speakers). If you do this make sure you disable LFE on the amp.
  10. Silent Fly
    Silent Fly
    Ridcully,
    I would suggest you to try the following:
    1. Turn the sub volume to zero. Connect your sub to the DVD player directly using the L (or R) output and play something. Turn up the sub volume (slowly). If you can still hear the hum it is the sub or the cable.
    2. If you cannot hear the hum with another cable, it is the cable.
    3. If you cannot hear any hum after test #1, it might be the amp. Connect the sub out of the amp to another amp line input. If you hear the hum is the amp.
    Silent Fly
  11. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    OK.
    Definately not the cable. Tried turning all speakers to small and that didn't work. Not going to be able to play any more until the weekend so will try the direct feed from the DVD then
    Thanks for the help so far
  12. James45
    James45
    Sep 21, 2002
    2,844
    59
    try a search on earth loop and hum
