SubWoofer connection
Discussion in 'Subwoofers' started by nja, Mar 14, 2002.
  1. nja
    nja
    Mar 1, 2002
    60
    Chatham, Kent
    +3
    I am thinking of buying an REL Strata III - my Hi-Fi amp is a Cyrus 5 and I also own a Sony DAVS800 system.
    As these REL beasts are rather expensive I would quite like to use the REL in both the hi-fi and home-cinema set ups. This would mean replacing the DAVS800 subwoofer (which is linked via speaker wire) with the REL. The Sony manual says do not use any other speakers with the system but they would say that wouldn't they ?. Any ideas if/how I can do this would be gratefully received.
  2. Jase
    Jase
    Mar 16, 2001
    10,818
    United Kingdom
    +2,694
    The Rels can be connected via both line level (phono) and high level (speaker wires).
    Double check its possible to connect the DAV speakers to another sub though as the Rels only have one high level input (a Neutrik gas tight connecter).
    If you have to run all the DAV speakers thru the sub then I dont think it will be possible to change.
  3. Jase
    Jase
    Mar 16, 2001
    10,818
    United Kingdom
    +2,694
    If its possible you could have the Rel connected to the Cyrus via the High Level connector and also connected to the DAV via the low level.
    I dont know what connections the DAV has.
