Subwoofer Cabling?
M
markshannon
I have currently just purchased a Elac home cinema speaker system along with a pioneer vsx d-912 receiver.
On the receiver i have a single phono 'sub pre-out' connection. On the Elac Subwoofer i have 2 phono L & R inputs.
How do i connect?
Do i need a Y-cable or can i just connect a single phone from either left or right?
mark
Ian J
According to the manufacturer's website both the left and right inputs have the same sensitivity so either will do.
M
Member 34135
You could use an Ixos 1009-Y1F splitter cable.
Andy.
forrestgump
you do not need a splitter cable mate, connect 1 phono to the lh sub out and the other to you amps sub out, my elac system sounds the dogs boll....s and should sound even better when mark grant;s sub cable arrives
Dfour
From what I have gathered the only reason you might need a splitter is if your sub doesnt wake up from standby very easily. It doesnt make any difference to the sound quality and costs more money.
Similar threads
