Subwoofer Cables
Discussion in 'Subwoofers' started by scrowe, Feb 22, 2005.
  1. scrowe
    scrowe
    Jan 8, 2005
    1,599
    116
    Brighton
    +1,055
    I've only ever owned 1x subwoofer, and that had a single cable.
    Yesterday I received a new Pioneer Ax5Ai amp with a dedicated subwoofer output and a Canton ADS 25 sub. The sub came with a Y-splitter (out of the amp) but no cable, and accepts seperate L&R phono inputs. Luckily I had a cheap phono cable lying around, but now I'm confused as to what cables to buy.
    I was looking at QED sub cables which all seem to be single connectors at each end. Assuming also, that my Y-splitter is a reasonable cheap connector, I want to replace it with a single phono to double phono lead.
    Would a decent quality stereo phono lead be the right choice? Is there something special about dedicated subwoofer cables, and do they come in the configuration I need?
  2. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
  4. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    better still !
    go to the power buys section and get it in two days from mark grant.
    dont need the americans for everything !
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    £16 or £60 hmmmm......
  6. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,452
    South Shropshire
    +88
    Get both and then do a double blind test and report the results back here!
    To be honest, with subwoofer cables I doubt you will be able to tell much of a difference but no doubt I will be corrected :lesson:
  7. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    I agree with you but you are hardly comparing like with like when you compare the price of a 3 metre cable from an American Ebay trader with the price for a huge 10 metre cable from Mark.
    As you can see here Mark charges a very reasonable £33 for the same length of 3 metres of Canare LV77S dual braided screen co-axial cable terminated with Canare impedance matched RCA phono connectors.
  8. Zone
    Zone
    Jun 24, 2001
    6,871
    Barnsley
    +2,674
    Lifted from Beekeepers Video Cables [MEGA LONG] All you need to know? Thread.
    Subs carry signals between 5Hz and say 100 Hz (ish). Unfortunately mains is 50 Hz and it is VITAL that these signals are kept away from the sub cable. This therefore NEEDS to be a mega screened coax for performance. This is the over riding performance issues for sub cables. It is NEVER mentioned here on this forum. All cables should minimise EMF but it is especially important for premium sub performance. At the moment, the wrong cables are being recommended / used for this channel. This is a cheap and cost effective upgrade to go with you ‘Gramma’ / BFD for that dream sub performance. If some one tells you it doesn’t make a difference…….. well you all know cables do make a difference
    Shielding, Shielding and More Shielding. You never have enough for sub operations
    Nuff said ;)
  9. scrowe
    scrowe
    Jan 8, 2005
    1,599
    116
    Brighton
    +1,055
    Thanks all,
    I've ordered a 3m cable and Y-splitter from Mark Grant in Cable Powerbuys
  10. bob1
    bob1
    Nov 7, 2002
    4,474
    Sheffield
    +133
    Glad i made a cable with ott screening then. :D
  11. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    sorry, had too many windows open... meant to compare the price of the tvcables cable not the mark grant one.
  12. mattty
    mattty
    I have a spare Digital Coaxial Cable ,could i use this ,ta :cool:
  13. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    It will work but it won't get the best out of your sub.
