Subwoofer cable.
Discussion in 'Cables & Switches' started by sapper44, Apr 29, 2005.
  1. sapper44
    sapper44
    Feb 12, 2004
    548
    uk
    +62
    This may be a stupid question.But i"m going to ask it any way.I want to move my sub.So i'm going to need a longer cable 10mtrs.Would useing a coaxel cables better than sub cables simple as that.
  2. Spooksta
    Spooksta
    Nov 7, 2000
    2,681
    Planet Earth
    +306
    Sorry to jump on your post but ive got a question 2.
    Is it ok to use a dedicated subwoofer cable for the video input on a vcr. Got a spare 10m sub cable that would be handy to use as a "video in" on a vcr - projector. A cables a cable isnt it, if it will handle both then should be fine true ?
    btw not sure on a coaxel cable m8
  3. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Spooksta.
    Very simple - try it and see.
  4. Spooksta
    Spooksta
    Nov 7, 2000
    2,681
    Planet Earth
    +306
    I have and it works but just wondered if this could be a bad thing to do?? :)
  5. av_guy
    av_guy
    Apr 6, 2005
    25
    Many cable manufacturer's claim that a Co-Axial (digital @ 75 Ohms) is designed to carry all frequencies (even though it is digital). Thus, should ideally not be used for a sub-woofer. Besides, a Co-Axial cable is used to input to an amplifier usually. Whereas, when using on a sub-woofer, you are using the cable to output sounds.
    Why?
    Well, a sub-woofer is designed to output low frequencies and ideally, you ought to use a specific sub-woofer cable, as it is designed with carrying a lower range of frequencies.
    How true is this?
    I'm not 100% sure. But, since I replaced my standard RCA lead with a digital Co-Axial QED Signature 75, it made no difference to me (just trying it out, as I was also curious) - at least I could not tell. I actually now use this cable for connecting the DVD player to the Amplifier for the sound carriage - yes, it made a big difference for the better.
    But!
    Once I replaced it using the QED SR-SW sub-woofer cable, I could notice a better responsee from our sub-woofer, able to play a low range of sounds better - more clarity in "thuds" and "booms".
  6. sapper44
    sapper44
    Feb 12, 2004
    548
    uk
    +62
    Thanks for the replies have sent for the sub cable.
