subwoofer cable
Discussion in 'Subwoofers' started by gover_1, Sep 17, 2004.
  1. gover_1
    gover_1
    May 21, 2004
    270
    hi im loking for a high level input cable for a rel stor subwoofer (xlr at one end, bear ends to go to speaker output of amp at other) anyone know where i can get one of these, in theory i can strip down any xlr cable , but wouldnt know which connections to make on the amp, so would prefer the cable designed for this, cheers, mark
  2. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    309
    +25
    Best bet is to pop into your nearest REL dealer and pick on up, £25 for 10m that can be cut down, the cable also has instructions for wiring.
    Good luck
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The connections are different to standard XLR wiring. I bought a standard XLR cable and had the local electrical repair shop rewire and resolder it for me for a fiver
