Subwoofer cable question...
Discussion in 'Subwoofers' started by jonnyv, Apr 1, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,305
    48
    +56
    I am using a 10 meter phono lead at the moment to connect my pioneer thx 7.1 amp to my yamaha subwoofer..
    the cable is a fairly standard quality phono lead...Is there a specific cable i need to get for best results or is a standard phono lead suitable..cheers...
    attached pic of curent phono cable....
    thanks for any advice
  2. eddiea
    eddiea
    I emailed Chord and asked which cable is the best for a Sub, the answer was a Cord Chrysalis Interconnect.
    So I ordered a 2 metre Chrysalis, works fine' sounds better than my previous 75ohm std interconnect.
    Regards
    Eddie
    :cool:
  3. Guest
    <irony>Wow, a manufacturer recommending one of their own cables, you must've been shocked </irony>.
    Mike.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I bet if you emailed Ixos they wouldn't recommend the Chord Chrysalis
  5. Lowrider
    Lowrider
    I think Eddie´s post is valid, anyone using one brand cables will probably do the same, and then he comments on his cable...
    I have some cheapish stuff from Tech+Link, no problems with the sound, but asked my dealer for something more hifi (I mean more money), and he is making me a pair of WBT 2020 with WBT terminals, of course...
    I will post if I ear any difference.
    What did improve the bass was, first a second subwoofer, later a better splitter from Monster cable, and spikes...
  6. eddiea
    eddiea
    Flimber and Ian J
    I could mention about putting brains into gear before replying but I won’t.
    Did it not occur to you both that I wanted to stick to Chord cables....? Derrr...., that’s why I asked for Chords recommendations.
    What you probably did not notice either is that they did not recommend any of their more expensive cables.
    I did not ask Ixos as I do not consider their cables to be in the same class as Chord.
    regards
    eddie:cool:
  7. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    The replies from Flimber and myself were specifically because it was your brain that was not in gear.
    In future we will work on our mind reading skills just in case we have to guess at the part of the answer that you don't bother writing.
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I am not sure this is an accurate statement. Yes I own substantial quantities of Chord and IXOS cables.;)
  9. eddiea
    eddiea
    Nic
    This is my personal opinion only, I had an experience with a Ixos optical cable where the end came off far too easily, It went back of course, I have not touched Ixos since.
    However I do reliase that Ixos sell more cables than Chord, also Chord cables are hand made where Ixos are mass produced.
    Regards
    Eddie:)
