Can I use speaker cable to run a decent subwoofer?
I've read up that subwoofer cable makes a big difference in quality and I'm worried speaker cable is going to sound even worse.
I've run speaker cable in the walls and through the floors to my AV Rack on the other side of the house.
I've been a bit of an idiot and completely forgot the subwoofer cable is different to the normal speaker cables and it's going to be a lot of hard work to run a new one. Also it will have to be at least 15m so not sure if you can even get them that long.
QED QX16/2 LSZH 2 Core Speaker Cable 100m Box - By Brand - AudioVisual Online - Home Cinema and Hifi Specialists this is the speaker cable I have running to where the sub was meant to go.
Any advice would be highly appreciated.
