Subwoofer cable for JAMO 325
Discussion in 'Cables & Switches' started by ener1, Sep 19, 2004.
  1. ener1
    ener1
    Aug 9, 2004
    1,421
    48
    +46
    Hi, i installed my JAMO system this weekend and found out that the power cable running from the subwoofer to the Elec socket is too short. Does anyone know if you can have these kind of cables made?
    thks
    Ener1
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    The only problem i would forsee would be the plug that connects to the sub has a 90 degree bend so it sits flush against a wall. One way to keep the origanal ends might be to cut it and solder a new section in and then shrink wrap when soldered.
