Any evidence to back this up?Yes the surround will be stiff. You'll get about a 10db gain when it's run in.
Plenty.Any evidence to back this up?
Please present some where a 10db increase is shown. 10db across the range? At a specific frequency?Plenty.
Plenty.
Manufacturers very rarely suggest weeks or months, more like a number of hours. The usual number of hours is something like 50hrs or so, maybe more. That’s approximately the amount of time it takes the cabinet and components to adjust to the temperature of the room.
I don’t do that. I open up the boxes, take the speakers out and put them in place. I then leave them there for a couple of days or so. After that I play them for a little and calibrate. Do they miraculously change into something else later on, no.
It sounds like the tone may have changed to you but not the output. And certainly not by any of the levels as suggested previously.
Don’t be concerned about the graphs, they wouldn’t measure a 10db difference just by some breaking in. That 10db difference though was someone mentioning Surround speakers.
Before I forget, I actually had a well run in MK X10 on loan for a month before I bought mine. I did a number of REW measurements while I had the loaner. When I got my new one, I could hear that it didn't sound as good as the loaner, so I measured it. I could see the slight differences between the measurements. After a week or so of running it in, it sounded better, so I measured it again. Guess what -- my new one now measured virtually the same as the loaner one.
Maybe I'm deluding myself, but I know what I measured and more importantly, what I heard.
