Subwoofer and my hifi ..
Discussion in 'Subwoofers' started by criggy, Jan 21, 2008.
  1. criggy
    criggy
    Dec 15, 2002
    765
    +81
    Quick question.
    Tomorrow, i shall be receiving my qacoustic 1010i package.
    Will i be able to connect the sub to my hifi for 2 channel duties as well as my sony dg910 for movies?
    If so, what are my options?
    Thanks.
  2. cunny678
    cunny678
    Jul 2, 2007
    5,701
    Manchester
    +693
    It depends if the sub has high and low level connections! Had a quick look at their website and brochure and there is no mention of connections!!!!!! When you open the box look to see if there is a AV phono type connection and a speakon type connection which connects to your speaker cable on you amp. I connected the pre out on my AV amp to the aux input on my Nad Stereo amp, the av phono from my sub out on my AV amp to the phono on the sub. Then the speakon connection on my sub to the speaker terminal on my stereo amp. You have to make sure to dont leave the volume on high on your stereo amp when using the AV amp for movies as this could damage the speakers!!
    All works great for me, but take care with your connections between amps and make sure you have pre outs if you connect both together - or there could be a loud bang!!!!!!
    Also if it has both connections, check the speaker manual to check if they can both be used at the same time!
    Chris
  3. criggy
    criggy
    Dec 15, 2002
    765
    +81
    Cheers for that.:thumbsup:
    Will check out the manual for the qacoustic's tomorrow.
    PS: sorry mods for posting this in the wrong section...:oops:
