Hi, I have a Harman Kardon HKTS210SUB that has died, the speakers fine on it but the board has died. Could someone please recommend or advise if there is another plate that I could use to get it working again?
Your choice of plate amps is limited and normally starting prices are over £100
Amazon have a used IMG stageline sam-200d for £63 which is as cheap as I think you will find.
I would imagine it is at least as powerful as the fitted amp (I very much doubt the HK has 200rms)
You will most likely need to do a bit of bodging to fix the cutout.
Worth asking HK if they can supply a replacement. Sometimes companies are very reasonable outside of warranty (and some are not)
Hi, thanks so much for the reply. Harman Kardon were no help at all, literally didn't want to know. I may bite the bullet and go for that amp and see if I can get it to work.
