Subwoofer advice needed
Discussion in 'Subwoofers' started by welshcelt, Jun 14, 2003.
  1. welshcelt
    welshcelt
    Jun 14, 2003
    4
    I've just bought a Mission m70as sub-woofer to complete my Mission m70 speaker set-up. I connected the sub-woofer to my AV amp - a Marantz SR4200 with an IXOS XFA01 1 RCA to 1RCA lead. However, I'm not getting any sound out of the sub-woofer. I've made sure the connectors are all going in the right places and set Subwoofer = Y on the amp. Should I be using a 2RCA to 2RCA lead or is the subwoofer faulty. The Mission helpdesk is closed till Monday morning so I thought I'd try here in the meantime. Any ideas?
    Thanks,
    Nigel
  2. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Sometimes the input is labeled "mono", the phono should go in this, if not experiment with both inputs but TURN OFF both your amp and sub.
    as a thought the phono out on your amp is in "sub out"?
    If it does need a dual input, Maplin do one for around £5
  3. welshcelt
    welshcelt
    Jun 14, 2003
    4
    Thanks,
    The phono out on the amp is labelled 'subwoofer' which is pretty clear cut. There are two inputs on the sub - one is labelled 'sub in' and the other is labelled 'lfe in'. The manual says to use the 'lfe in'. But I've tried both and neither work.
    Nigel
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
    Things I'd check:-
    Have you got mains power feeding the sub (I'm assuming the subs active)- usually a light emits to show power present.
    Have you connected the Sub out on the amp to the lfe in on the sub correctly.Have you tried an alternative interconnect to make sure the original one's not faulty.
    Set the subwoofer to on/yes and LFE to SUB or Mains And Sub on the amps menu.
    If this doesn't give you any joy then your next step would be to approach mission or you amp dealers since it could also be the amp (unless you've tried another sub and that works ok)
    good luck m8
