subtitles using 'help' key
Discussion in 'Satellite TV, Sky TV & FreeSat' started by wormvortex, Sep 9, 2005.
  1. wormvortex
    wormvortex
    May 29, 2005
    5,700
    South of Heaven
    +395
    hi,
    u know how on sky u should be able to press help and it brings up a box allowing u to select subtitles and narrative options well mine don't work, it works fine on my sky box in the other room but on the sky+ box pressing help does nothing at all. Anyone had this problem and/or know what to do to fix it?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Your SKY+ may not have the latest software, it is currently being rolled out with the PACE v1 getting it a week or so ago and the v2 this week, Amstrad and SKY+160 models probably at a later date.
  3. wormvortex
    wormvortex
    May 29, 2005
    5,700
    South of Heaven
    +395
    i did one of those force download thingys but it didn't do anything, do i just gotta wait then?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You're lucky it didn't do anything :)
    You shouldn't do too many forced downloads - there's always a risk that it will fail, and leave you with a pile of junk. When the software is available for your version of box, the box will download it automatically. Upgrades usually appear overnight Monday/Tuesday.
