subtitles on digital tv
Discussion in 'Satellite TV, Sky TV & FreeSat' started by zoolap, Mar 27, 2002.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    I have ntl digital and same may apply to others. To activate subtitles you must do the following:
    press "guide"
    select option for settings
    move to the subtitles
    change this to on or off depending on what you want.
    On teletext it was only:
    text > 888
    or subtitles button.
    Why not use one of the coloured buttons to toggle subs on and off.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,408
    Manchester
    +151
    You can....It's the YELLOW one.
    There's no need to go through all those menus just to toggle subtitles on/off.
  3. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    I'll try this tonight. Assuming you are right, may I say in advance "doh!". :)
  4. Kevo
    Kevo
    Aug 23, 2001
    5,408
    Manchester
    +151
    Forgot to say...
    Press the 'TV' button first and it clearly says in the middle, 'Turn subtitles on yellow button'.
