Subtitle settings for DVD playback
Discussion in 'Microsoft Windows' started by TheCrow, May 18, 2005.
  1. TheCrow
    TheCrow
    Jul 16, 2004
    660
    2
    28
    London
    +76
    I am getting a little frustrated with MCE subtitle settings. :thumbsdow
    If I select "None" on the DVD settings page I see no subtitles but this also appears to remove forced subtitles too. i.e. when watching an English language DVD where there is a short section of "foreign" language no English subs appear.
    If I select "title default" then often (but not always) I see full English subs in the movie until I go into the DVDs menu and select no subs. This then has the desired effect i.e. I only see forced subs for foreign language sections.
    But this means every time I play a DVD I have to go into the DVDs language menu and set subs to none. :thumbsdow
    Does anyone else have this problem?
    Is there a cure?
    Also I cannot find a way to switch subs while the movie is running. On just about every other DVD player you can switch subs on/off or toggle sub language from the remote or by right clicking the mouse. I cannot see how to do this in MCE without going back to the main settings page. This makes my problem even worse.
    Can anyone help me :lease:
  2. tbensmann
    tbensmann
    Jun 17, 2008
    I have the same problem...
    It still amazes me how such a product can lack such a basic function!
    Especially when it comes to switching between subs..
    If anyone has a solution... I'm all ears!!!
