Subtitle problems w/ Shaun of the Dead
Discussion in 'Movie Forum' started by DocShock, Sep 17, 2004.
  1. DocShock
    DocShock
    I just recieved a Region 2 Shaunn of the Dead DVD - the movie was awesome, but for some reason the subtitles will not turn off. I didn't turn them on, but they are always there, no matter what I do.
    I have a Cyberhome DVD which I made regionless and have watched Region 4 and Region 1 DVDs without this problem. Shaun of the Dead is my first region 2, but I didn't expect that to happen.
    Anyone have any advice or know how to overcome this problem?
    Thanks so much!
  2. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    quite a few people have had similar problems with this disc with many different players, it played ok on my player, there is nothing you can do about it, try it in another player
  3. DocShock
    DocShock
    What type of DVD player do you have? Is it regionless? What's the best regionless DVD player on the market - might be an investment I'd like to make. Thanks for the reply!
  4. chic
    chic
    Jul 1, 2001
    5,976
    glasgow
    +871
    i have a toshiba 510 which has been made multiregion,normally the more expense the player the more reliable at the less problems you should have with it, i paid £300 for my tosh 2 years ago and i am well pleased with it i have only had one disc in all that time which gave me problems.My first player was a chepo grundig and that gave me no end of problems
  5. nwgarratt
    nwgarratt
    May 5, 2002
    26,440
    +2,871
    It played fine in my Sony NS900 adn Ebench KH777. It showed the subtitles on the Pioneer DV350.
  6. girliedrinker
    girliedrinker
    Jul 11, 2003
    78
    London
    Admittedly it's a bit of a weird disc for me - can't fast forward, rewind or pause. I've also had the subtitles problem but cured it by pressing "Subtitles Off" on the remote whilst in the main menu and starting the film again.
  7. Pug72
    Pug72
    May 10, 2003
    1,992
    Hereford
    +277
    I had to select subtitle 6 to have none onscreen.
  8. DocShock
    DocShock
    I'm going to play around with it tonight and see if I can figure out an option to shut the subtitles off - I doubt it will work thought, but hell, it's worth a try. Thanks for the suggestions!
  9. dts_boy
    dts_boy
    Nov 26, 2001
    2,544
    Manchester suburbs...
    +145
    i have had this problem tonight on my arcam dv27. i had turn to off subtitles and then alos the commentries in the setup menus on the film then it played just fine!
  10. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    I had exactly the same problem on my HTPC using Theatertek and the only way to switch them off was to go into the subtitle menu on the dvd menu : switching off internally to TT had no effect.
    Some of the extras had exactly the same issue.
    I'm inclined to say its a disc problem judging by the amount of people experiencing the problem.
    Rubbish UK mastering houses again most likely.
