Subbing
Discussion in 'Subwoofers' started by todinks, Dec 18, 2001.
  1. todinks
    todinks
    i have the denon 3802 amp and am eagerly awaiting the availability of series 3
    i simply adore the slam bang bass from action movies and need a sub for this purpose, not so much so for music
    its come down to the foll:
    b&w asw1000 vs b&w asw2500 vs rel q400 vs rel storm III
    (1) b&w or rel?
    (2)the b&w1000 and rel storm III are bigger than the other two
    should i go for a big sub...does a big sub give better bass...... space is no constraint
    could anyone pls give me some advice.....
  2. Lowrider
    Lowrider
    A bigger sub, same range, will produce more bass, and deeper...
    Even better is two subs, as the sound will fill the room better, I have two REL Strata III...
  3. pc
    pc
    if space is not an issue, get a dem on a M&K push / pull sub. MX125 is amazing. If the room is a fair size get yourself an MX350. wow!!
  4. RajUK
    RajUK
    Dec 18, 2001
    157
    Reading
    +6
    as an existing rel owner, i'd say go with the storm
    personally i have a strata III and it's great for movies and music
    Raj
