sub woofers
Discussion in 'Subwoofers' started by jan, Dec 9, 2001.
  1. jan
    jan
    Iam thinking of replacing mo cannon d500 pro logic amp with a kenwood 5050.My sub woofer at present is passive .the 5050 output says pre subwoofer on it .Does this mean that it needs an amp to make it work on the 5050
    any help much appreciated
    jan
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,035
    Inbetween Upgrades !
    +7,332
    What ???
    I think you need to re phrase the question !!!
    Kev
  3. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    The subwoofer output on the amp is for an active subwoofer only (with built in amplifier). A passive subwoofer has to be connected across the speaker terminals of the amplifier probably as you have them connected at the moment.
    You will lose the bass management facilities of DD and DTS dvd's by connecting in this manner.
    Ian
  4. jan
    jan
    thanks Ian.I thought that might be the case
    jan
