Mobbsc2000
I have a Denon 3806 AV receiverand a Tanoy surround sound speaker system
I need to run the Auto Set up facility on the Reciver for Room EQ and Speaker set up as per the manual
I do not understand where to set the various controll knobs on the Sub Woofer
For Instance, how much volume do I set for the Receiver to make its test noises, Half way?
Do you turn the crossover LFE switch off?
Do you set the theatre control to max theatre?
Where does the LFE Control go max or min
Phase control which position is that set to for the set up?
Can somebody help please
