Sub woofer question (simple)
Discussion in 'AV Receivers & Amplifiers' started by bunbenho, Feb 14, 2002.
  1. bunbenho
    bunbenho
    ok...i am a newbie, so be gentle ok..
    i read the operation menu for connecting subwoofer to the amp.
    it indicate i need a Monaural audio cord to actually to do the work, is the Monaural audio cord just like the normal white and red audio cord, or is it something difference?
    thanks in advance!:eek:
  2. andy-p
    andy-p
    It's simply referring to a single (low level) phono lead, i.e. one plug on either end and therefore mono.
    Andy P.
  3. orangemirrors
    orangemirrors
    yes it is like the red and white cable you mention (with phono ends) and if ness only one plug connected at both the amp and the sub i.e if the amp has one output for the sub then plug the white phono plug in and the other white end in the sub in the left input if it has l & r inputs or otherwse if the manual says so.
    the thing you have to remember is although you get sound out of this the better quality the cable you use the better
    hope this has been of some help and dont worry how simple you think your questions are we all start at the beginning and need some help
