Sub Woofer Change
Discussion in 'Subwoofers' started by mikatt, Jun 2, 2004.
  1. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    Hello
    Can anyone tell me whether the Mordaunt Short MS 308 sub woofer is a lot better choice than a Eltax Atom A8.2 sub At present I have the Eltax
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    If you can stretch your budget to £220 have a look at the Mordaunt Short MS309 which is now the sub to beat.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    As Ian J said go for the 309 its much better than the 308. Superb cheap cub :smashin:
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,228
    2
    +3,713
    If it is on your budget, the 308 is generally better than the Atomic series (although the A12 is quite cool) but as the previous posters state, the 309 is way better than the 308- tis why we built it :).
  5. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    Thank's for the advice/suggestions now all i've got to do is persuade the wife. One further question re position of sub woofer i've heard that it can be placed anywhere ie behind the settee as that is my main stumbling block she don't like a box on show. any thoughts on this one
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Change the wife :) :D upgraded models tend to be more receptive to these kinds of things :) :D
  7. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    Now there's a thought, trouble is nobody else would have me.
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Yes you can place the sub anywhere as bass is omni-directional.
    The easy way to find out the best place for the sub is to place the sub in your listening position, unplug your main speakers and play something very bassy while walking arround the room listening for where the bass sounds the best to you.:D
