Sub Woofer Booming Noise
Discussion in 'Subwoofers' started by beano1938, Dec 19, 2004.
  1. beano1938
    beano1938
    I've got problems with a Kef psw2000 sub woofer - it makes a booming sound every 20 seconds or so (sounds like a heartbeat) - tried exchanging the unit and have the same problem with the new one - no problems with the Energy sub woofer the shop has lent me pending solving the problem: receiver is Denon AVR 2802. Anyone got any ideas on what is causing this or how I can sort it out?
  2. beano1938
    beano1938
    I'll give these a try and let you know if it works - thanks for your help
