Sub with cellar below ....
Discussion in 'Subwoofers' started by jkharmer, Apr 26, 2007.
  1. jkharmer
    jkharmer
    Apr 11, 2005
    448
    28
    Stockport
    +29
    Hi there,
    Would a downward firing sub (e.g monolith DF) be a bad idea with a full height cellar underneath? or does this make no difference?
    Any help would be great.
    Thanks, James
  2. Helicon
    Helicon
    Apr 4, 2005
    5,016
    +261
    It all depends how solid the floor is. Is it a wooden suspended floor or a concrete floor? They'll both make things sound different.
  3. jkharmer
    jkharmer
    Apr 11, 2005
    448
    28
    Stockport
    +29
    Seeing as you are also up at such a late time ....... (I am working / formuming ever now and then!)
    It is a suspended wooden floor, I wonder whether some sort of slab under the sub would help??
    James
  4. Helicon
    Helicon
    Apr 4, 2005
    5,016
    +261
    If it's one of those flimsy suspended floors that bounce when you walk on it, a slab will definitely make a difference and should tighten things up. There are also isolation platforms to try like the Auralex ones, which i'm using on a suspended wooden floor :)
  5. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    You could also make use of it directly by creating an Infinite Baffle sub in the cellar. Great sound (I'm told).
    Greg
  6. Nimby
    Nimby
    Jan 27, 2004
    9,246
    The Danish Bacon Factory
    +700
    Absolutely! No modern home is complete without a few holes in the floor. :)
    Examples in the IB Cult gallery:
    http://home.comcast.net/~infinitelybaffled/page2IB-Gallery.html
    I have a rather flimsy floor where my big downfiring SVS has been sitting for a couple of years. It is a raised platform which I inherited from the previous owner. I really couldn't hear any difference with (or without) a heavy slab underneath the sub. Slabs are cheap enough to be worth trying and discarding if you notice no difference. Try different material underneath the slab to improve isolation. (Carpet tiles, sponge, sandwiches, etc.)
  7. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    My thoughts exactly, I wish I had a cellar, IBtastic :thumbsup:
    Adam
  8. Sawdust
    Sawdust
    Mar 16, 2006
    141
    +9
    I hope I'm not hijacking this thread but I have a question about IB subs.
    My setup is in the attic and I have loads of space at the eaves and mounting drivers in the walls would be a doddle. My question is whether a plasterboard wall is enough to isolate the rear sound from the listening room. I appreciate I would need to build something substantial to mount the drivers in and fit them to the joists but I'm concerned that the plasterboard won't provide enough isolation.
    Mike
