Sub Wiring....
Discussion in 'Subwoofers' started by sofaboy, May 18, 2002.
  1. sofaboy
    sofaboy
    Hello all ........
    can anyone answer a little question..... I have a yamaha yst-sw 305 sub...200w and a Yamaha 620 amp
    I have wired it via the speaker connections from my amp ( front speaker B) to the From amplifier inputs on my sub.... I also have a Pin jack input on my sub and a Pin jack sub output on my amp
    Im very happy with the sound I get now from my sub, but I was just wondering if it would sound any better using the Pin jack or as it is.... I cant just do it as ive built it in an enclosure....
    Cheers all.....
    :eek: :eek:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    If by "pin jack" you mean phono then you will get a better sound using this "low level connection"
    You are currently not making full use of the .1 in the 5.1 which is where many of the effects are deliberately placed by the sound engineer as these are directed to the sub through the phono output only.
    By making "high level" connections as you have, you are only receiving the normal full range and not the extra bits.
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,537
    Newcastle
    +330
    It depends how you have configured your AV amp.
    You can either set it to "Large" main speakers, "No" subwoofer and use the high level inputs or "Small" main speakers, "Yes" subwoofer and use the low-level input on the sub.
    Cheers,
    Liam
