sub which must be furniture too :-)
Discussion in 'Subwoofers' started by crackles, Sep 29, 2004.
  1. crackles
    crackles
    Hi all,
    Time to get a sub. To keep the wife happy, it must match the (cherry) colour of current furniture and be real wood rather than MDF. (what a crazy request...asthetics before sonic performance, but there you go!!!)
    So, I was thinking how about the BKXLS everyone here raves about, or possibly the Mission MS5AS? Is the mission worth the extra money?
    Are there any other Cherry coloured wood quality subs for the £300ish mark that could be suggested?
    Also, perhaps a dumb question but are the analogue amps a fire risk!? They get rather hot, and on a carpet....
  2. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    The reason I want a smallish sub ... like bk xls200 ... I can easily put a small square-ish glass table over it, next to the sofa.
    see......
  3. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    I cannot comment on the BKXLS.
    However, check the following for a kick ass price on the mission
    http://www.discounttv.co.uk/missionspeakers.html
    There is also the MISSION VOLARE V6AS SUBWOOFER @ £399.95 from Superfi.
    Alternatively, look at the Velodyne CHT-R range from across the pond. I've just ordered a CHT-12R from Uncle Eric.
    Good luck :)
  4. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    Scum Utd... nevermind... but great FANTASTIC prices for all things on that website!!
    thanks!!
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    They look very nice but £469 is an awful lot for a sub with a manufacturer's claimed response of 25-120 Hz +/-3 dB when you can buy the BK Electronics XLS 200 with similar performance levels for only £279
  6. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    That mission sub is quite a size so does that mean that size is not an issue.
    An amp would not be fitted into a wooden box if it was a fire risk ,so i think you will be safe .It would only cause a fire if it was faulty and any eletrical item could cause a fire in that case.Don't :smoke: that helps.
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It also has a huge round port on the front and anyone with young children could well find it being used as a post box
  8. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    :laugh: It took me a while to get all the plastic knives and forks out of my old speakers.
