Sub upgrade!
Discussion in 'Subwoofers' started by Dittohead, Apr 13, 2002.
  1. Dittohead
    Dittohead
    Hi All,
    Definately time to buy a new Sub. Got about £800 - £1000 to spend. Quite tempted by REL, maybe Q-400E or Storm III.
    Any thoughts? Rest of the speaker system is all Mission:
    704 Fronts
    77C1 Centre
    77DS Rears
    Cheers.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    If size is no problem then look at the M&K V125 at £945, best sub in the price area, won the HCC award also.
    If size is a problem then look at the B&W ASW 2500, £895. A very good little sub.
  3. Dittohead
    Dittohead
    Thanks man.
    The M&K looks like it could be just the ticket.
    Time to go shopping :)
  4. eddiea
    eddiea
    If you are going to listen to music as well as HT I would recommend you try before you buy, the REL especially.
    regards
    eddie:)
