Sub to replace and better my svs 20-39pc+
Well im tempted to replace my svs cylinder......however it must be better!
What is there at the moment for betweem £500-£1000?
If its a lot better then yes...... Ill just have to get it resprayed gloss white like my cylinder ;)
Badger0-0
You don't get a lot better than a 20-39 unless you spend serious money :)
Even then, it probably involves two or more in your room.
hoppaz
Why not just get a second one and have it painted. It looks like you have the room.
This would be my suggestion.
Yes I may have to go down that route. Thinking of replacing the amp in my cylinder with the new 800watt version. And update the driver from
The 12.3 to the latest.
Badger0-0
That's not going to give you what you want and having seen the prices, it'll be a waste of money, imo.
As Hoppaz said, get another one.
Or preferably three :eek:
Or consider making your own?
With your room, you need to shift a lot more air.
Making your own could give you something like a couple of quality 18" drivers :smashin:
I have no wood/DIY skills lol.
Could try and bed someone to make one for me. So long as its no bigger than say 1meter wide x 1 meter deep, height dont matter, and it's gloss white and performs damn good it will be great
Badger0-0
I've no wood skills either.
With those dimensions I reckon DIY would definitely your best bet :smashin:
Quite like the idea of running a dual white 20-39pc+ setup
Badger0-0
It still won't be enough mate.
Are you getting the message yet? ;) :D
So what's the solution? An ultra? Cylinder or box?
Badger0-0
Even an Ultra won't do it in your room, imo.
You need way more to pressurise it.
Assuming you're the same Daddy K who still has my digital SPL meter? (It doesn't matter :D)
Yes, that's me. But a different house ;). Quite similar in size thou. So I'm gona have to make do or spend silly money
Badger0-0
:D
If the room is a similar size, stepping up isn't going to do what you want.
You need a serious upgrade.
You aren't going to get that with a better commercially available sub at £1K, even S/H, imo.
Go for a DIY job and look for someone who'll happily build it for you.
Easier said than done, I know :)
Damn. It's annoying knowing I've peaked out unless I spend silly money. The sames happened with the tv if I wanted to go bigger too now I'm at a 60 inch, silly money to go bigger :(
Similar threads
Trending threads
