Sub to match Mission M73's?
Discussion in 'Subwoofers' started by Ex-Ronny, Jan 14, 2002.
  1. Ex-Ronny
    Ex-Ronny
    Jan 14, 2002
    7
    I've just bought 4 x M73 and an M7c1. In addition I would like to have a sub - especially for watching DVD's. Right now I'm trying the Mission 7AS1, but I can't say I'm too happy with it. It seems to me that it's just "booming". I know I'm not too good at tuning it, but I was wondering if anyone has a suggestion for another sub that would play nice with the other speakers.
    Ex
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    What about the Mission M70as, the subwoofer from the M70 series?
  3. Ex-Ronny
    Ex-Ronny
    Jan 14, 2002
    7
    Yeah, I read about that one on the Mission web page. The problem is that I don't think the importing company here in Norway will import this sub. Thanks anyway.
  4. bob007
    bob007
    All depends on your budget.........you are looking at £500+ for a decent one.
    Have a look at the reviews for REL and M&K
    If on a tighter budget Yamaha do a good range YST SW160, YST SW205, YST SW305 the 305 is only £200.
    Another option...go to Pricerunner >speakers>subs, look at what your budget will buy you and then get the reviews for it.....either on the hardware reviews here or by posting.....
