Sub switching off with Yamaha RDS 5640
Discussion in 'Subwoofers' started by Futski, Jun 10, 2004.
  1. Futski
    Futski
    Jan 5, 2004
    20
    Hi have just bought a cheap-ish sub which has left and right phono inputs and a dedicated sub input.
    The left and right outputs work fine. However, no sound comes out of the sub with only the dedicated sub output from the amp attached and then unit just switches itself off.
    I have ensured that the amp settings are correct i.e. sub yes, 1 E Bass to SWFR or Both and nothing seems to make any difference.
    Please can someone help me to get the direct sub connection working in order that I can get the true 5.1 sound.
    Can anyone help....please :lease: :lease:
  2. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Are you saying the sub works OK with the sub output from the amp going 'in' the sub left or right input. If so just use the Left In which is the norm. Not sure about a dedicated input on a sub as I've not come across this myself. What make/model subwoofer is it, someone else may have experience of it.
