Sub Suggestions?
Discussion in 'Subwoofers' started by chriskenny, Aug 12, 2005.
  1. chriskenny
    chriskenny
    Hi folks, have just acquired set of kef kht 5005 speakers but require a sub for the system. I am running Pio 435xde with Denon 3805 & 3910. I am open to suggestions and will spend around £400ish. Your recommendations will be appreciated.
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,096
    +381
  3. Timmy C
    Timmy C
    Oct 10, 2003
    5,096
    +381
    Sorry, just read the end of that thread and someones had the last one!
  4. binbag
    binbag
    Jun 16, 2004
    1,714
    North Kent Coast, SE UK
    +81
    You'll find a lot of love on this forum for the BK XLS200 which is under £290 delivered. I've had mine for a couple of days and it deserves the superlatives that others have given it.
  5. kbfern
    kbfern
    Aug 17, 2002
    17,780
    Wolverhampton
    +5,950
    Plenty of subs around £400 depends on whether you need waf or not.BK monolith around £420,SVS PB10-ISD around £400 + as binbag sugests XLS200 at less than £300.
    Do try to demo if you can,there is plenty written about all these subs on this forum.
    Any of the above subs offer very good value for the money as you are buying direct from the manufacturer and avoiding dealer markups.
  6. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
