kevshed
Hi all...
Suggestion time please... who can help with the scenario below
Just in the process of upgrading Arcam AVR100 to FMJ AV8/P7 combo. Currently speakers are Kef 2005 kit - fine for the avr.. but clearly lacking for the FMJ.
However, i dem'd the FMJ on the eggs - just to get an idea, and frankly i was pleasantly suprised at how well they sounded.. certainly were driven much better and closer to their limits than the AVR could - (dont underestimate them! - for cinema anyway)
The lacking point by far is the sub... if i change that now, im sure i'll be happy until i can scrape the funds needed for a 7 channel MK or B&W setup.
Ultimate plan is to replace them with MKs or similar, but not until ive appeased the mrs about the amp upgrade.
Question is:
I need to replace my Kef 2005 sub (pretty weak), with something around the same sort of physical size - can go slightly bigger, but not much. So, am after a recommendations for a smallish THX sub. I am on a budget, so suggestions of discontinued - used models also valid - would really like to spend well under £1000.
Cheers all.. look forward to the inputs, as always
Kev
Question is:
Kev
