sub spikes?
Discussion in 'Subwoofers' started by hamtaro, May 3, 2003.
  1. hamtaro
    hamtaro
    im waiting delivery of a vx 10[thanks eric]and now have noticed that i don,t have the lead to connect it! what do i need to buy,and how much should ibe paying. lastly will i be able to put spikes under the sub, or would 2 sqaush balls cut into half help?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    You can buy an Ixos 3 mtr sub lead from hifibitz for £10 or a Profigold one from Eric at about the same price. Spikes are not recommended for subs and the rubber feet on the sub should be sufficient.
  3. hamtaro
    hamtaro
    thanks,.......out of curiosity,why are spikes not recommended?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Spikes are a hard coupling of the sub to the ground and even though the point of the spike is narrow it will still transmit vibrations. The best way to decouple a subwoofer is via rubber feet.
  5. nathan_silly
    nathan_silly
    I use a Rel Storm with spikes with a concrete slab- it sounds much better with the slab.
    Floor is wooden, 1st floor (room below my room)
  6. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    There are no rubber feet with the vx10 just rubber pads,not really suitable for a carpet.
  7. hamtaro
    hamtaro
    i have carpet, ....so i use what?
  8. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    I used the rubber pads but when i get chance i'll put some large rubber feet on.
