A
AndyGB
I have had a cheap Eltax sub for over a year now but have never had it plugged in as we were in the process of moving and then decorating so my AV system has only just been put back together again. But now it comes to it I can't find the damn manual, so have no idea what the switches on the back do.
It is an Atomic A-8 and has a Phase switch that can be set to 0 degrees or 180 degrees, a low pass frequency dial which ranges from 50 Hz to 250 Hz and a subwoofer level dial (I assume volume) ranging from 0 to 10.
Can anyone tell me what these do and what I should set them to ? The rest of my audio equipment is a Denon 3801 and Mission M72 series fronts, M70 centre and M70 DS surrounds.
It also has high level out and high level in spring clips as well as a line input phono socket, are these used for connecting to the amp if you don't use a phono lead ?
I know that in the future I will probably need to upgrade it but at the moment that isn't an option.
Many thanks
Many thanks
