Sub set up!!!
Discussion in 'Subwoofers' started by Flanners, Jun 17, 2003.
  1. Flanners
    Flanners
    May 21, 2003
    126
    Kent, UK
    +5
    Not again?
    Quickie, what order do I set it up?
    1. Volume on sub
    2. Cut over between 50hz and 150hz
    3. volume on amp
    4. position and angle of sub
    5. Phase 0 degrees or 180 degrees (what the fudge?)
    Not really sure?
  2. nathan_silly
    nathan_silly
    1) Up to you
    2) Roll-off on your other speakers
    3) Depends on your AV amp/subwoofer gain
    4) Depends on your room and best bass sound
    5) Normally 0, 180 is when having two subs and one is cancelling out the other.
  3. Flanners
    Flanners
    May 21, 2003
    126
    Kent, UK
    +5
    cheers heres to many hours faffing!
