Sub Sat connection confusion
Discussion in 'Home Cinema Speakers' started by Grif, Aug 27, 2004.
  1. Grif
    Grif
    Jul 28, 2004
    261
    +4
    I'm in the market for a speaker package and from what I understand the sub is connected to the amp via sub out/left line in, and the sats connect to thier corresponding posts on the amp.
    If this is the case, why do most of the subs I've looked at have terminals for the sats :confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Some people like to feed their sub with a full range signal and using the sub's crossover, filter the higher frequencies out to the satellites.
  3. Grif
    Grif
    Jul 28, 2004
    261
    +4
    Thanks Ian.....is it better to hook'em up that way then (sats to sub) or does it depend on the system?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I think that you will find that most forum members will connect the satellites directly to the speaker terminals on the amp and rely on the bass management within the amp to filter the signal correctly
  5. Grif
    Grif
    Jul 28, 2004
    261
    +4
    Thats what I'll do then :thumbsup: When I get some speakers :blush:
    Thanks Ian
