Sub sat choice
Discussion in 'Home Cinema Speakers' started by phattanglo, Jan 6, 2005.
  1. phattanglo
    phattanglo
    Nov 6, 2004
    105
    16
    Can anyone offer some guideline on a sub sat system.
    I have a couple of choices within my budget based on prices at RS and Superfi.
    My choices will probably be between Tannoy FX5.1 and Elac Cinema 1 mk 2.
    I need the bass to be as extended and tight as possible, it will be used for very occasional music and is not going to be used for massive volume levels, well maybe now and then!
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    Can I ask what your budget is?
    Consider the Wharfedale Diamond 9 HCP system which has had good reviews and sells for £500.
  3. phattanglo
    phattanglo
    Nov 6, 2004
    105
    16
    Alas just 200 squids
