sub required need help
Discussion in 'Subwoofers' started by Tony, Jan 15, 2002.
  1. Tony
    Tony
    Jul 22, 2000
    34
    Harrogate, North Yorkshire
    hi all,
    i'm searching for a decent sub on a limited budget.
    I was considering the Paradigm PDR-10 or PS-1000. Richer Sounds told me that the PDR-10 has had a lot of problems with humming in standby mode (has anyone heard about or experienced this).
    The PS-1000 is bigger than i wanted to go.
    Richer Sounds suggested the Mordaunt Short MSW-20 (has anyone any views on this).
    Any other suggestions will be greatfully received.:confused:
