Sub question
Discussion in 'Arcam Owners' Forum' started by MonkeyNutz, Mar 25, 2005.
Tags:
  1. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Hi, I hope this isnt a silly question:
    I`m going to be buying a second hand avr100 soon and Ive been looking into which speakers to get. I looked on the back of the unit and it only has 5 speaker outputs (front L/R, rear L/R and center), i was wondering where the sub is connected too?
    Can this unit drive a passive sub or is it best to buy an active one and connect to the pre out?
    thanks
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Hi - like most AV amplifiers and receivers the AVR100 is designed to be used with an active subwoofer. You use the sub pre-out to drive this.
    HTH
    John Dawson (Arcam)
  3. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Great, thanks for the help.
