Sub Positioning
Discussion in 'Subwoofers' started by xtremecool, Jan 4, 2003.
  1. xtremecool
    xtremecool
    Dec 9, 2002
    25
    3
    Cheltenham
    How many of you have spent time trying to find the best position in the room for your sub only to find it was there in the first place.
    I spent about an hour moving it round and trying test tone sweeps only to find they all lacked something the original position had, so ended up putting it back.
    Also running sweep tests doesn't half warm up the sub amp, the heat sink got hot enough to be uncomfortable to hold onto after the tests were finshed.
    Jon
